Hello everyone,
I am setting up an off-grid solar system using Victron equipment and I need some clarification regarding proper bonding and grounding practices. My current setup includes solar panels mounted on a metal structure, connected to a charge controller and inverter system. I want to ensure that the grounding and bonding are done correctly for safety and system stability.
I have a few questions:
- Should the solar panel frames be bonded to the same earth grounding system as the inverter?
- Is it necessary to separately ground the DC side and AC side, or should they share a common grounding point?
- What is the recommended approach for bonding metal mounting structures in Victron-based systems?
- Are there any specific Victron guidelines or best practices I should follow for grounding in off-grid installations?
My goal is to ensure proper safety, avoid potential grounding loops, and maintain system reliability.
Any guidance or references would be greatly appreciated.
