SmartSolar MPPT RS 450|100 External Earth Fault Alarm
I am trying to achieve an external Buzzer/Light for an installed system with a SmartSolar MPPT RS 450|100. In the spec sheet I can see there is a programmable relay, can this be assigned to toggle on Earth Fault to then toggle a contactor coil for an external earth fault buzzer circuit? If not is there another way that this could be achieved.
TLDR: External Earth Fault Buzzer on SmartSolar MPPT RS 450|100 how to achieve this.
If you don’t have a 450/100 available, check out the VictronConnect demo to see the relay-on-alarm feature. You can also use Node-RED to monitor for error #41 (panel isolation resistance too low) and automatically trigger alerts or activate a Cerbo GX relay when ground faults occur.
Thanks Owen, I have a 450/100 available. Was just wanting to program the relay to toggle on panel isolation fault, so I can run an external buzzer to the building. So as to make people entering aware that the metallic structure could potentially be “live”. I understand the 450/100 is Galvanically Isolated so this issue should never arise but, it’s a safety at request of the end customer.
I Will have a look into the Node-RED suggestion you have said.
Thanks!
I need to do the same thing. My two Cerbo relays are already being used by other functions. The MPPT RS 450/200 relay is available.
@AzzaD Did you find a solution? If so, could you tell me what it is please ?
There’s no “relay mode” for a ground fault of MPPT RS 450 in Victron Connect.
I’m not a software developer, but if I don’t find another solution, I’ll try programming with Node-RED. :frowning:
Could someone explain to me, in general terms, what needs to be done with Node-RED to achieve the following please ? :
  • In case of a ground fault (pv1, 2, 3, and 4): MPPT RS 450/200 relay: OFF
  • Conversely
I tried in VRM, my installation, settings, setting alarms, MPPT450/200, I switch ON these :
#41 - Inverter shutdown (panel isolation resistance too low)
#42 - Inverter shutdown (ground current too high: >30mA)
#43 - Inverter shutdown (voltage over ground relay too high)
I try to wire the ground on negative or positive (during 1hour) but a didn’t receive any alarm.
Hi all,
I created a simple program in Node-RED.
It works.
But with relay 2 of the Cerbo (Venus device).
Her is my setting :
  • A Stored: MPPT 450/200 MT (3) > /Pv/IsolationResistance :
Custom input => MPPT 450/200 MT
Measurement => /Pv/IsolationResistance
Name => pmasse
Preview => (100000000 < 700000)= X FALSE
Condition 1 :
Operator => < (less than)
Threshold => 700000
Output when TRUE => 0
Output when FALSE => 1
Debounce (ms) => 2000
  • relay control :
Relay => Venus device
Measurement => Venus relay 2 state
Value types
  1. Open
  2. Closed
Initial value => Don’t set initial value
Name => stop relay
Attached, a picture of my NodeRed.
One problem : I can’t control the RS450 relay by the same way :
  • relay control :
Relay => MPPT 450/200 MT
Measurement => Relay on the charger
Does anyone know why?
