Good morning, I want to use the SmartSolar 75/15 with a 400W solar panel (42V, around 10A). I would like to know if the MPPT regulator, for charging the battery, will output 12V at around 30A or if there is a limit in the output current of the regulator.
Because if I have an output limit I will go with a smaller solar panel.
Thanks
The maximum current output will be 15A
From Datasheet. MPPT 75/15 ==> 75 => Maximum solar panel voltage / 15 => Maximum current
