Smart Shunt - state of charge
If the SOC is not increasing when you charge it indicates you have not wired the shunt correctly and the charger negative is connected to the battery negative, not the shunt system negative. See the FAQ I wrote, there is also another about synchronisation settings thst you should read. Pinned topic at the top of the DIY section.
