Smart Battery Protect to cut off part of 12v circuit
I have a Victron 12/24 smart battery protect. The leisure battery in my campervan powers the fridge and some LED lights. I would like to use the SBP to cut off the supply to the12v fridge only rather than the complete 12v circuit. The fridge is supplied very simply with just positive and negative (earth) connections.
Would this be an acceptable application?
@koliwood The maual has some examples and yes it is used as a protection device to automatically disconnect loads if the voltage reaches a specific programmed level. A switch can also be fitted to the remote terminal to manually switch the load.
