Small CCTV Box
Im looking at building a small box for a camera with a way to have 110v input with a 12vdc output for charging. I need remote viewability for the system charging etc. Any ideas? Yes we are on a budget.
What batteries are you charging. What part does the camera play in this? What is the project for? Do you need mains power for something else or could solar do the job?
Hi there we are to far north for solar, we are using a 100ah deep cycle battery. This will be used for surveillance. We will have 110v ac at all times but if the power goes down we need a fall back for temp power.
Multiplus 500VA (Inverter/Charger) + Cerbo-S (Monitoring) + AGM battery is a solid UPS solution for small comms applications.
