Show us your Android GX WI-FI display installed
Yes, I have had multiple devices connected at the same time. Works fine :+1:
Good Morning,
The Ulefone Armor 13 works fine, I scanned the code, set the wifi, and that was all.
It now has the latest features, very very nice.
See photo besides a Cerbo screen.
Regards, Jeroen.
Good afternoon,
See below link, if you want to make your “old” Android into a display as well.
Regards, Jeroen.
This is so nicely done @PieroM - It looks factory fitted.
hi, what device is this?
It is an 8” android tablet
Onn 7” tablet from Walmart. Cheap, barely usable as a tablet. Works perfectly for the console.
An old Sony Xperia X Compact embedded into the panel using a router. Unnecessary components such as speakers, microphone, camera and battery were removed and powered by a DC-DC converter.
Installed on Android POE powered 8 inch tablet in my living room.
Hi MichaV4, do you keep the screen always on? Did you avoid the long loading time each time you switch on the display?
Best regards,
Martin Diehl.
no, the screen turns off after a minute, but reloading after double-tapping the display only needs 5s
kind regards,
Micha
Hi @B51-technician ,
I see you’ve managed to display separate L1, L2 and L3 load bubbles on your dashboard.
Am I correct in assuming you’re using a VM-3P75CT?
My Cerbo GX is running Venus OS v3.75, and the VM-3P75CT measurements are visible under Device List, but I can’t get the separate load bubbles to appear on the Overview dashboard.
Do you remember if there were any specific settings or configuration changes required?
Thanks in advance.
Hi @OppieKoppie , I am using a Carlo Gavazzi EM540 as GridMeter.
Your Meter seems to have a different role. Maybe this leads to a different behavior on your display.
