Shelly Device automatic disconnection
My Equipment:
Cerbo GX OS3.80
Multiplus II 5kva
SmartSolar MPPT 450/100
Shelly PM1 gen 3 firmware 2.1.1
Shelly addon with temperature sensor on PM1
When enabling the Shelly device in the remote console it is available as a switch on the VRM tab. But it automatically disables after some hours and require activation in the remote console again. Is this a known bug? What is the workaround?
I used Node Red to add the temperature onto my VRM dashboard, but I have not yet managed to successfully add the PM1 as a controllable Switch yet
Are you using static IP’s on the device?
The IP has been the same for a long time. I am not the only one that has been having this issue, some other installers have resorted to using Node Red because of this
There are Shelly devices with firmware issues, some of these were discussed when the features were released.
Some use DHCP which had issues with auto-discovery. There are topics on this from earlier.
