Ongoing Shelly issues
I have some issues with Shelly 1 Gen 4 devices that just disappear from the VRM and Cerbo.
They are being used as 12v smart switches.
Latest version have done it over multiple versions 20260923-075739/2.0.1-ge1a198b
Cerbo 3.85 but has similar issues going back to 3.70 which were supported to have been fixed.
All devices have static IP address and reserved in router, eco mode is off, they respond from the Shelly app and work as expected but just disappear from anything victron.
Any suggestions, is this still being looked at?
Only way to get them back in VRM or Cerbo is reboot.
Did you also try to add the IP-Adresses of the shellies in the GX Shelly integration manually?
Otherwise the GX is requiring MDNS discovery to work flawless and that has all sort of “challenges”, starting at the shellies, but also general problems like routing issues or even rate-limiting of broadcasts by the router itself, etc.
(I had some older shellies, that stopped broadcasting MDNS after a certain uptime, since I added their IPs to the GX integration manually, never had any issues anymore)
Yes have them manually entered in integrations/shelly devices,. That hasn’t helped
