Shared voltage and current sense (DVCC) without BMS Control
I have got a system set up with Victron Easysolar (multiplus, victron mppt etc). Currently, I use DVCC and so management of my battery is left to the BMS. The best thing with this is that I get shared voltage and current sense, so no voltage differences between my multiplus, MPPT charger and BMSs. However, that also puts the BMS in charge of the battery (external control) and so I lose the Bulk-Absorption-Float monitoring. Is there a way or planned feature to allow shared voltage and current sense, but without DVCC giving up the charge/battery control to the BMS?
Have you tried setting the controlling BMS in dvcc to none?
Yes! This is exactly what I was looking for. It wasn’t there in v494 firmware that I was using before. I saw after your answer that v552 makes this possible and it is just bellissimo!!
Great, glad to help. Be so kind as to accept the post as the solution if you are satisfied your query is resolved. Thanks.
