Setting charging source priority
Hello everyone,
I’ve bought a EasySolar-II 24 250/70 GX, I have some PVs connected, AGM batteries and sometimes I’m connected to the grid through AC IN.
My problem is that I want the Grid to charge my batteries, even if the panels are producing, is it possible ?
Thanks !!
I will elaborate a bit, the problem seems to be a lack of communication between the inverter/charger and the MPPT.
On the easysolar diplay, when I’m on the grid only, the HUB-1 shows the charging state, like :
HUB - 1
Float
But if I turn the panels on, then I have a second display that shows Solar : Bulk at the same time.
If I check my batteries then, it shows I’m actually in bulk,.
So my question would be : is there a way to make the MPPT consider the HUB-1 status ?
Despite being an electrician, this is my first tango with Victron devices (I previously had a “real” all in one inverter, that was much more limited) and I’m totally lost with all the options/Interfaces (Victron connect/Remote console/VEconfigure).
Help please !!!
