I can set two voltage sources on the Smartshunt. Source battery and starter battery, however the voltage scales are mismatched and one even starts at negative voltage.
I would like to have same voltage range between y axis tick marks.
Swapping item measured and resetting histories does not seem to reset the scales.
Is any customization possible.
