Bonjour,
Installation Off-Grid Solaire 24V - Easysolar 230V - Tinyhouse en 230V donc avec FI et mise a la terre
Les lumieres scintillent, visible evidement la nuit
Le easysolar doit fonctionner pour le frigidaire.
Des cas similaires ? Et des solutions ?
Merci
Didier
Some LED lamps are particularly sensitive to voltage fluctuations.
I use low voltage DC LEB bulbs in some of the house, this has no issue.
The AC led lamps do occasionally flicker, but only when dimmed. If your flickering is related to the fridge cycling, you could try an inverter type fridge that cycles less frequently and has a slower start up ramp.
Thx for your answer
Chnaging the fridge is not an option and I don’t know if that is related to fridge cycle as reported by “customer”.
This is more a “head” story 'cause the flickering can be seen…frequency = not healthy.
As far as I know, no dimmer installed.
