We are looking to replace the system we have. We want to connect a landline, generator and solar ( over an mppt). We will have 6 12v 150AH in series parallel (Lithium) batteries, what do you recomend?
@JimLatimer
you Need
- a Quattro which has two AC_in (Land, Generator)
- A GX device: Ekrano, Cerbo or Raspberry Pi with CAN hat
- dependig on your a BMS cable, or acnew BMS
- A capable DC bus bar Like the Lynx
- a lot of cables
- an Internet connection for VRM
- AC distribution and fuses
I suggest you contact a local victron dealer for designing your system,
6x 12v batteries in series is not possible, system voltage would be too high
4 is the max
I should have said it will be a 24v system.
