I have a 2022 Grand Design 261BH, that has solar panels on roof along with a Furrion 25A charge controller. I had changed my 2 lead acide batteries for (2) 100aH LifePO lithium batteries. Its been charging and working fine, but wanted to have a Charge Controller that worked better with lithium batteries as the Furrion controller only charges my lithiums to 80%.
I swapped the charge controllers, pretty simple. Plugged the wires in on the SmartSolar and it powered up. I could read it on the bluetooth connection on my phone. It shows the battery charging when im connected to shore power, but it’s showing that my solar panels are not charging the battery. I checked all my fuses in the normal spot, all wires are connected as should be. Please help!
Thanks everyone, from the fuses I know of, none are blown. I’m going to reach out to the RV manufacturer if there’s a fuse hidden somewhere else specifically for the Solar.
In the meantime, can you elaborate more on “polarity” and what you mean by that comment?
Ah dang, well there goes that idea then. Well, though out-of-box failures are uncommon with Victron, they’re never impossible, so time to get in touch with the seller and file a warranty claim!
So, I had one of these (a 100/30, also in the HQ2601 serial range) as an RMA today, same symptoms of not recognizing PV input with a known-good known-polarity input, and discovered that Victron has added a PV relay control to these units. I have no idea when it was added, and it’s not documented anywhere yet, but seems relevant to the OP here as well.
Get into the Device Info page (follow these instructions 5. Configuration and settings) and if the PV relay has tripped, there will be a button there to click to reset it. Once it’s been reset, the button disappears (thus I don’t have a screenshot of it to share).
In the case of the unit I had here for an RMA, the unit immediately began responding normally and charging as expected once I’d reset the relay.
