I have two of these
that I had pro installed inside a van with a Victron Multiplus-II
I am charging them either with an exterior outlet in the parking lot at my work (through the day while I work, charging at 7amps) or with a generator I have attached to a hitch mounted cargo carrier behind the van (charging at 28amps).
The outlet at work is not reliable and often turns off throughout the day, so often I use the generator.
My issue is that generally I cannot tell what voltage the batteries are at, and I am worried the incompatibility between the two will eventually damage the batteries.
I have both the bluetooth victron connect app on my phone, and the usb version to my laptop (which often makes the mouse jump around crazy on my laptop).
The VictronConnect app usually always shows 85% capacity even when in the 12v range.
When I return to the van after working, if it is still charging, it shows the battery voltage jumping around between 13v and 15v all crazy, while still in the 2nd stage of absorbtion, with the wattages in/out doing weird things too. (see vid) It shows 85% full, but I know they are full because they end up at 13.6 after unplugging.
Twice I returned and the voltage had gone from above 13v to 12.4 (it had been reduced weirdly to almost dead throughout the day). Often times the outlet looses power because they use the line to plug in the trucks when not in use and it seems unreliable generally.
I know the voltage the victronconnect app is reading is generally not accurate, and since the charger cannot read the batteries correctly, I fear the batteries eventually become instable because they are charging them wrong (not going into the 3rd stage of absorption, shoving power in there when they’re full etc, or doing other weird things).
I just charged the batteries with the generator at 28amps for a couple of hours. VictronConnect now shows the batteries at 13.25V, but it never went into the 2nd stage of absorption, but I did notice the wattage coming in when from 2400w to 1800w shortly before I shut down the charger.
… Is there a way to always read the battery voltage without the VictronConnect app (which doesn’t seem to read it properly for whatever reason)?
Have a multimeter permanently attached to the batteries?
Is there any possibly of damage or injury by continuing to use the charger in these ways?
Is there any changes to the settings that I should do? I have the latest firmware on everything. I have the float voltage at 14.4 (as per Renogy), and the other setting above that (in the app) is always 0.1v above the float voltage, so it’s at 14.5v. The one setting at ‘adaptive’, I forget which setting that is.
I have been talking to both Victron and Renogy support for weeks with no result.
I have attached a couple of videos of the charger doing weird things after returning to the van after work, and one other video of it starting to charge.
Why is a new user restricted to 5 uploads lol.
