Hello all,
We just released a new version of VRM. Here’s what changed:
Dashboard
- Improved Layout for Grid Meter Systems: The dashboard now displays a parallel layout with AC Loads and Critical Loads when a Grid meter is present, replacing the Hub layout. This ensures visibility of Critical Loads.
- Unified Control for RS Units: A single card now controls all RS units in a system, simplifying the interface. This is collectively referred to as the “AC System.”
- New MultiRS Controls: Added support for Input Current Limit control, ESS, and DESS for RS systems.
- Optimized SOC Limit Display: The Active SOC limit is now displayed when the ESS mode is set to “Optimized with BatteryLife.”
- Enhanced AC Inputs Details: Details in the AC Inputs (Grid/Shore/Generator) section are now shown even when a Grid meter is not present. These measurements are sourced from the Multi RS/HS19 (AC System).
Custom Date Range
- Validation Alerts for Date Range: You are now alerted if an invalid date/time range is entered (e.g., “from” date/time is after “to” date/time).
New user registration
- Optional Country and City Fields: Country and city fields are now optional during registration.
Advanced
- Improved BMS History Display: Time since the last charge is now displayed in days and hours instead of just hours in BMS History widgets.
