Relay output timer
Is it possible to configure a relay output on the Cerbo gx to be active for some time after triggerring with a DI. Want to heat up hot-water tank for half an hour, but then switch off automaically (to not forget it). Know I can do it by setting up Nodered, but are there any more basic function to do this directly in the Cerbo?
A very clear NO … there is (still) no way to link the DI with the DA. Especially not via time functions such as release or activation delay.
Then you absolutely have to switch to NodeRed
Hi, this is possible with RemoteGPIO mod (search in the DIY section) and configuring the Dingtian Box to link Digital inputs with the Relay.
