Congratulations!
I decided to upgrade the equipment of my solar station. Now the Deye inverters are installed. I am eagerly awaiting the start of sales of the Multi RS19.
I wrote my own program to monitor the Deye inverters. I like using this program, I got used to it. When switching to the Multi RS19, I would like to read the sensor data from victron to my program.
Having read the documentation from Victron, two ways are visible:
read data from the GX device via modbus.
read data directly from the ve.can.
The first method has a drawback - not everything can be done via modbus (for example, I cannot change the absorption voltage).
The second method has a drawback - I did not find a list of all the PGNs that can be used for Victron equipment.
Please advise.
Thanks!
I read. I got acquainted. I have not come across a form of recording bit data anywhere similar to:
7.0.0.EF.FF.20
or
6.0.1.F2.0E.20
As I understand it, this is a description of a 29-bit Сan ID.
If we discard the explicit byte description 0xEF 0xFF 0x20 (24 bits), then 5 bits remain. That is, the description 7.0.0 or 6.0.1 describes 5 bits.
I don’t understand.
How do I translate 7.0.0 or 6.0.1 into a 5-bit binary number?
Thank you!
(3 bit priority) . (1 bit reserved) . (1 bit data page) . (8 bit PDU high/format) . (8 bit PDU low/specific) . (8 bit source address)
7.0.0.EF.FF.20 will become CAN ID: 1CEFFF20 6.0.1.F2.0E.20 will become CAN ID: 19F20E20
19F21240 CAN ID will translate to: 6.0.1.F2.12.40
See that the PGN is in fact a 17 bit number, (1 bit data page).(8 bit PDU high).(8 bit PDU low)
In the above example, PGN is 1F212 (DC Detailed Status).
