Hello all.
I have a Raspberry Pi 4B with the latest Venus (v3.42) and the package manager RpiGpioSetup (v4.10). I have hooked up my 2 relay module using jumpers.
VCC → pin2
In2 → pin 40
In1 → pin 11
GND → pin 20
Jumper set to JDVcc - Vcc
Everything works, the opposite of what it should. When I toggle the relay to ‘on’, the resistance between Relay NO and Relay Comm, goes to infinite. When I toggle the relay ‘off’ the resistance between Relay NO and Relay Comm, goes to 0.
Please help
LEGACY assignments for Relay 1, 5 and 6 and Dig In 4
WILL CONFLICT with second channel on WaveShare dual channel CANbus hats, and possiblly others
interrupts, chip selects and second SPI bus
single channel CANbus hats should be OK with these assignments
this includes using only the first channel of the WaveShare dual channel hats
note that WaveShare sells two different dual channel CANbus hats: the non FD and FD (flexible data rate)
for use by the RpiGpio package on Raspberry PI platforms ONLY
This is a list of GPIO pins, set by the script /etc/rcS.d/S90gpio_pins.sh
They are documented at: bbb gpio · victronenergy/venus Wiki · GitHub
Format: <pin_number> <direction: in/out>
The part is used to create an symlink in /dev/gpio.
relays are active HIGH
Relay 1 GPIO 21 / header pin 40
21 out relay_1
Relay 2 GPIO 17 / header pin 11
17 out relay_2
Relay 3 GPIO 27 / header pin 13
27 out relay_3
Relay 4 GPIO 22 / header pin 15
22 out relay_4
Relay 5 GPIO 23 / header pin 16
23 out relay_5
Relay 6 GPIO 24 / header pin 18
24 out relay_6
these have pull UPs
Digital input 1 GPIO 5 / header pin 29
5 in digital_input_1
Digital input 2 GPIO 6 / header pin 31
6 in digital_input_2
in stock code these have pull DOWNs
modified to pull UPs by the GPIO overlay that is installed as part of this package
Digital input 3 GPIO 13 / header pin 33
13 in digital_input_3
Digital input 4 GPIO 19 / header pin 35
19 in digital_input_4
Digital input 5 GPIO 26 / header pin 37
26 in digital_input_5
Gracefull shutdown input
Note this input is NOT added to the available I/O used by Venus OS !!!
GPIO 16 / header pin 36
16 in digital_input_6
