Raspberry Pi 5 with NVME HAT - Venus OS does not work
after I recognized it is for me not possible to boot Venus OS from proxmox virtual machine (on RP 5), currently I try to boot Venus OS from NVME HAT.
The state of RP 5 eeprom
# rpi-eeprom-update -a
BOOTLOADER: up to date
   CURRENT: Fri 25 Sep 15:59:09 UTC 2026 (1790351949)
    LATEST: Fri 25 Sep 15:59:09 UTC 2026 (1790351949)
   RELEASE: default (/usr/lib/firmware/raspberrypi/bootloader-2712/default)
            Use raspi-config to change the release.
I had flashed the ssd with the current rp5-large.wic file and add to the config.txt of the boot partition (Venus OS) the lines
dtparam=pciex1
dtparam=pciex1_gen=2
#dtparam=pciex1_aspm=off  # energy saving
#dtparam=pciex1_msi=off   # message send interrupteds
#dtoverlay=cma,cma-96     # pool size 96 Mb
If I try to start the system from the ssd than I get no ethernet connection to the system (led flash is off).
What I does make wrong?
Can someone help me?
Best regards,
Thomas Enzinger
What advantage do you see in the NVME HAT specifically for Venus? Just pop in an SD card and you’re done; it can’t really be used for anything else anyway.
I should also say, though — I started out with a Raspi. I added various extras, such as dbus-serialbattery, a TFT touchscreen, and so on.
Something was constantly going wrong, so I gave up and bought a Cerbo.
And in terms of price, it hardly makes sense these days either — when you look at the cost of the Raspi, the DC-DC converter you also need, and the MK2 cable.
It’s about performance. Far more powerful CPU. The Ekrano, for example, did double the core count, but single core performance stayed the same.
Although with the Cerbo MK3, and another upcoming product, there may finally be enough.
For example, I have 16 MPPTs currently (painful shadow situation). So a more powerful CPU may allow me to go beyond the 25 MPPT limit, provided it isn’t hardcoded somewhere.
Being on the bleeding edge of hardware is often counterproductive for system stability.
Venus isn’t exactly IO constrained so flash isn’t a limiting factor. The new mk3 and its 64-bit OS is quick.
Imo the juice isn’t worth the squeeze going down this route.
But in modifications it is more about the journey than the destination :wink:
In the case of an NVME drive, it’s really about reliability. An SSD is expected to last a decade. An SD card, not so much.
There is little difference in the memory architecture used on the device itself, the interface is different but retains the same flaws. All comes down to what the manufacturer has bolted the interface to. Not really a concern for this use case either. You’re engineering a solution to a problem that doesn’t exist.
There is a lot of myth and myth-understanding about the reliability of these devices and how failures manifest.
You’re going to cook a dram module, or another arbitrary part long before flash will ever show a problem.
