referring to “Control MK3-USB connected inverter/charger system” in DVCC
I set up a system with 3 MP-II for a 3 phase ESS system today, which works flawlessly. Added a 4th MP-II to charge the battery via generator, hardware is wired and 4th MP-II shows up in Venus-OS.
I need to add, that I use a Pi4 with two MK3 interfaces, so no internal VE.Bus connector.
Is there any documentation available how to configure the 4th MP-II connected via separate MK3 USB interface? Are there any assistants needed and is CVL, CCL and DCL also reflected in the dbus path of the 4th MP-II?
Is the minimum SOC also reflected in the 4th MP-III? I see that the primary system (3 phase) is not charging as the minimum SOC is reached while the secondary system (single MP-II in Charging only mode) is still charging, even if the minimum SOC is already achieved…
If there is any documentation available, a link would be great, I couldn’t find on.
Thank you for the great feature!!!
