I’m in the planning phase for a 1st time van build and want to be able to charge 24V house batteries with solar, alternator using a dc-ac inverter, and shore power. I currently have 240 volt 50 amp charging available at home for an EV so will be utilizing this source at times. I understand that the Quattro ii 2x120 will automatically switch to the active source. Documentation states that output will match input when connected to a source. The van will have multiple 120 volt loads but no 240 loads. I assume I can limit output to 120 volts even if using a 240 volt source. Is this correct?
