On a boat I have a big battery bank of Lithium with a Lynx BMS and Quattros in parallel to charge them.
Now there are also Skylla-TGs in parallel on the same boat, primarily for the wide voltage input range.
My question is, how could I use the Skylla-TGs in parallel to the Quatros to accelerate charging?
I was thinking of programming the Quattros internal programmable relay to be activated during bulk charging mode and use that dry contact to control the Skylla-TGs over the REM input, so that the Skyllas would only assist in charging during bulk charging. I might also combine that with the BMS charger disconnect output for additional safety.
Any reason why this would not be safe to do?
Thanks for any input
