The local substation was burned down and since the new transformer was installed my Quattro 10kw inverter does not seem to like the power coming in from the grid. It switches some circuits off and others have very low voltage and also will switch on and off. As soon as I disconnect the grid the system works perfectly from the pv. The voltage is within acceptable range of 220-230v but I am not sure what the frequency is and if there is voltage drop in milliseconds. Is there a way to adjust the parameters for the power coming in from the grid? And is this safe to do if possible
Related topics
| Topic | Replies | Views | Activity | |
| Quattro 24/5000 not switching to grid? | 2 | 86 | 1 February 2026 | |
| Quattro not connecting back after AC grid lost | 33 | 711 | 26 July 2025 | |
| Quattro isn't syncing with the grid | 9 | 137 | 1 April 2026 | |
| Quattro won’t invert in 60hertz | 26 | 384 | 8 June 2025 | |
| Generator concerns/confusion | 5 | 245 | 29 August 2025 |
