Hi- I’m looking for input for on my inverter/24V electrical system upgrade of my 2024 Grand Design Imagine 2600RB travel trailer.
I have done lots of research and will be installing a 24V 230AH Epoch battery bank and a Victron Multiplus-II 24V 3KW 50-7- 2x120 Inverter into the trailer. I’m taking a phased approach and want to understand each part of the system and install it in phases.
I want to integrate this into the existing electrical system. The 12V DC system is wired for 30A. I plan to do a load test on the 12V system to validate the amperage within a week or so.
My trailer already has solar and a Furrion 40A MPPT. It also has an Inverter AC prep line on a 30A breaker which I will use for the phase 1 install. I will also max out the MPPT with solar panels up to 960W.
Later, I will add another Epoch 24V 230AH battery and more solar panels with another MPPT controller. Someday I may run a full wire from Shore power to Inverter and back to breaker panel.
The first diagram shows my current installation. The second diagram shows the Inverter, Lynx Distributor & Shunt, Cerbo GX, and Orion 24/12 30A DC-DC converter, etc, all connected to the existing 12V DC, Jack, and breakaway switch. It also lists the wire sizes.
I plan to disconnect alternator charging. I will update my tow vehicle in a couple years and will revisit this then.
WRT the Jack and emergency break away switch these are currently always connected to the 12V battery. I do not want to deal with a 2nd dedicated 12V for this purpose for simplification. Thus, I have used a 100A mini busbar to power them from a second positive 8WG wire from the Orion. The battery disconnect does disconnect power to them, not sure if this is up to code.
WRT Fuses: I need to size the fuses in the Lynx Distributor and Shunt and the fuse on the pos battery wire.
Finally, wasn’t quite sure on the grounding of the Furrion. It currently is grounded in the pass through, then the neg battery output cable is grounded under the trailer which is connected to the existing neg 12V battery. The original connections can be seen in the first diagram. The new connections in the second diagram.
Lots of info here… I appreciate ALL comments, especially those related to Wiring size, fuse sizes, ground connections, etc.
Thanks!!!
Bill
