I returned to my cabin after 6 weeks and when I tried connecting to the inverter via bluetooth I could not. It only showed up as a black bluetooth interface box, not the usual blue and did not respond on button presses - no light came on.
I did long-press the button when leaving but usually it wakes up in seconds. Not sure what made it catatonic.
I therefore disconnected the negative lead and reconnected (with a spark!) and now it seemed to have turned on - for a brief second. Now it blinks both green and red. The manual says to reduce voltage (continuous blinking is “high battery” = high DC voltage)! Any clues? Tried unplugging multiple times. No difference.
Worth mentioning:
It has worked fine up until now
I used it to vacuum last time
I turned it off (all lights off) before leaving
The time before that I only put it in stand by mode, but that almost drained the battery, hence why turning off.
There was a spark when I reconnected the negative wire
Last night when I arrived it had 12.2V. Now batteries are charging, so it’s about 12.9V. quite normal range. No difference.
