Overhead wire regs
I have an array I want to install about 80’ from cabin, the ground is loaded with rocks so I can’t realistically did a trench to run the cable.
What is the code to run overhead or on top of the ground
Depends where you are, and what voltage you are running.
Generally if it’s a public area not subject to motor traffic, 2.5m above ground will do.
