The support of Orion DC-DC converters is not explicitly mentioned in both Cerbo GX or Venus OS documentation. Did I overlook the documentation ?
Is it effectively supported ?
Thanks
Thanks
Ok, clear.
Additional question: what about the control via the remote switch. Is it necessary or the software switch is enough to stop the output for instance if the battery is full or for maintenance ?
Not sure what you mean.
The Orion has a charging algorithm so it will should stop charging automatically if the battery is full.
For maintenance I would recommend to use the HW switch not SW.
