Orion XS 50A Network Status
Hello all,
I have a system with a cerbo gx, smartshunt 1000A, orion XS 50A charger, 4 100Ah NG lithium batteries, a VE.bus BMS NG, and a 150/100 mppt. I noticed that in the device information page for the orion that it says “network status: standalone”. Is this normal? Considering that everything is connected through the cerbo and dvcc is enabled I find it strange for this to be the case. Even when active and charging it remains at standalone. Does this need to be connected to the smartshunt via the smartnetwork over bluetooth?
Hopefully someone can help to clarify what I am seeing. Thank you!
No, you don’t need to do anything there (don’t mix the smart network with the GX)
What is means is it will follow its own charge algorithm and set up. And is normal in a mobile system.
Which BMS exactly? DVCC is very different for the models.
@lxonline Thank you for the response.
It is the VE.bus BMS NG that gets its power from the cerbo GX. I neglected to mention this has a quattro 12/5000 inverter also so it connects directly to the cerbo/quattro via ve.bus as well as jumped in series to the batteries via the m8 cables.
I will assume it is the V2 then.
Each device will follow its own internal settings.
So make sure to program them right.
