I have an Orion 12/12-30 DC-DC non-isolated charger hooked up to my old Toyota Motorhome.
I’m monitoring my leisure battery with a Victron Smart shunt. The system all works as expected except for the Orion DC charger.
With the engine running and the Orion unit turned OFF - The Victron App shows the that the Orion unit is receiving 14.5v from the alternator/starter battery. When I turn the Orion unit ON and it starts “bulk charging” the alternator voltage drops to 13.5 and my smart shunt shows a 5amp DRAW on my leisure battery. I’ve left it running for about 30 minutes at a time and the unit barely gets warm to the touch and appears to just be drawing from my battery.
Has anyone seen anything like this before? I’ve triple checked my grounding points and even tied my leisure and starter batteries negative terminals together via jumper cables and achieved the same results.
I have one more thing to try that was suggested to me from someone on Reddit and that is to remove the remote switch I wired up (which seems to be working fine) and replace it with the OEM jumper. I’m going to give that a try this afternoon but I’m out of ideas after that.
I’ve also heard that I might be wasting my time even trying to fix this inefficient unit… Would love to hear thoughts because I’m stumped.
Thanks.
