If this is true this explains the lower watts. So watts is the maximum continuous active power up to powerfactor 0.8 which has a higher VA, at power factor 1 the watts remain the same.
Below powerfactor 0.8 the VA remains the same but the active power (watt) drops.
Still not specified clearly if this is true imo.
