On VRM, how to create an alarm if the used current (negative current) is too high?
The problem is that in VRM, when I want to create an alarm, I can set a negative value. for instance if I want to check that used current is always below 4Amp, I should write “-4” value. But I can only write positive value in the box.
is there a solution ?
in printscreen, here is the (french) screen for alarm creation where I can’t write negative value
Hello it is strange i didn’t have any answer. Maybe i didn’t post my question on the correct channel ?
Hi @iostrym , I think that is an overlooked use case from us when we added validation to those fields. I will make sure that we correct this, so also negative values can be saved here.
Thank you for bringing it up!
Actually @iostrym , I just checked and negative values are actually accepted.
Could you share the product type and parameter you try to set this alarm up for?
