On/0ff doesn’t work as it should - on/off
Why do my ancient cheap inverters (1200W and 600W) work fine, but the Victron Phoenix 12/500 on/off has been crapping out from the start? The unit just refuses to work as it should! The old spare better?
Just like turning a light on or off, you don’t have to be professional, do you? Or if you start the car, you just turn the key… The equipment should serve the user and not the other way round?
@180268 Please consider removing these useless posts that contain not a single bit of information that may help explain the problem you encounter. I suspect you are overloading a 400W inverter that cannot be compared with the larger units you refer too.
