OCPP and Victron EV Charger?
Hi Been reading thru OCPP on the EV Charger. Every thing I’ve found including Victron AI Support says this is available on V2.04. However I don’t see the OCPP Tab appear.
Anyone have any tricks?
Hi, OCPP is not supported yet.
You can probably do this over node-red, here is an example - node-red-contrib-ocpp (node) - Node-RED
Hi Lucian,
Thanks for this I’ll look into it.
Any reason why the Victron AI Support does indeed say that it is supported when indeed it is not at this time? Specifically with V2.04?
Cheers
Cam
like any other AI, sometimes is wrong. You can check the manual and search for OCPP.
