Noise and heat from 24v vs 12v MultiPlus-II 2x120v?
A novice question, but assuming the same 120v AC load, would a Multiplus-II 2x120 in the 24/3000/70-50 version run quieter and cooler than the 12/3000/120-50 version? Running in Invertor mode, not pulling power from Shorepower.
Thanks.
Cheers,
Same load = same losses = same heat
There shouldn’t be much difference.
Matthias, OK, thank you.
My novice brain was thinking that because the 24V inversion to 120V is less “work” than the 12V to 120V, then perhaps that means less noise and heat (i.e. more “efficient”).
Cheers,
Hä???
Ludo, When you say “much cheaper” can you explain a bit more?
Also, I should add that part of what is behind my question is I"m trying to decide whether to install a 12v Victron Lithium NV battery bank (4 x 300ah) or a 24v Victron Lithium NV battery bank (2 x 300ah) in my RV trailer.
Of course, I will be pulling not only 120v from the Multiplus II, but 12v also to service the 12v loads in the trailer.
And yes, I understand that one of the challenges with using the 24v battery bank is making sure my Solar panels provide at least 29v - 30v to the Victron Solar Charge Controller to “wake it up”.
My largest potential 120v load will be running two Truma Aventa A/C units (with SoftStart). I know I can’t run them long, even with 1,200ah battery bank, but there will be time when I need to run them for awhile.
Thanks for your input.
Cheers,
Bryan
Unless there are promotions running in some specific area, Google is likely mixing up models (as it is known to do).
The MP-II 12/3k 2x120 MAP price is $1088, while the MP-II 24/3k 2x120 MAP price is $1145.80
What has the price and weight to do with the efficiency/produced heat?
(There is not much weight difference)
The 12V model doesn’t contain 250€ more of copper.
That would be 35kg of copper.
The price difference comes from the different production capacity in the factory.
The 24V and 48V are sold much much more than the 12V model and therefore the production is cheaper.
To compare prices you should use the official pricelist not Google.
Why isn’t for me to determine, I just checked the actual prices from Victron at this moment in time and that’s where they are /shrug/ The 24v 2x120 is in fact more expensive than the 12v 2x120
But the street price has nothing to do with the production price.
(And the amount of copper inside :smile:)
The ratio is different yes but you can use the same amount of copper.
Some more windings on primary some less on the secondary and you change the ratio but have the same amount of copper.
Datasheet of the 120V units:
They all have the same weight :scream:
It’s magic!
The 48/5000 is heavier than the 24/5000 !?
Here are the two that I am considering. They both have the same form factor and the same weight.
with 24V you have cheaper cable, fusing, etc. to use :slight_smile:
Yep, thanks, that’s certainly in the “pro” (benefit) column.
Cheers,
