Hi, is there a node to see the state of a MP-II? see picture: scheduled.
I can’t find it.
If there’s not @Victron can it be add?
It is quite easy to find this info, it is recorded in the modbus register.
You can also take a custom input node, choose the category as vebus system/inverter and scroll through the available list.
It is right there as /state
It returns a numeric value which is defined in the docs as:
0=Off;1=Low Power;2=Fault;3=Bulk;4=Absorption;5=Float;6=Storage;7=Equalize;8=Passthru;9=Inverting;10=Power assist;11=Power supply;244=Sustain;252=External control
That node I found, but I need the “state” Scheduled as seen above.
What value does it return in scheduled mode?
Scheduled is technically an ESS state, not a vebus state.
That I don’t know. I honestly don’t now how to see that.
Another question are you using DESS for scheduling? As there are fields that DESS data can be pulled from. What are you trying to do?
I don’t use DESS.
I have a node red flow for charging an EV. When the state is scheduled, I want to stop charging. Now I look at the grid meter, but looking at the state scheduled is easier.
Ok, see what the state is that it reports at this time, using the instructions above.
Scheduled charge active:
Hi Nick,
I think this is it.
At this moment I’m buying and the state changed from 0 to 1
thanks
