Recently i get this fault when Deploying updated flows. Let 5 times ok en then this …
Then I have to reload , everything is always fine updated so means this fault is not related to Node Red.
What is the reason for this and how can I solve this?
That is typically seen when nodered is restarting, so it would appear something is causing it to crash or the GX to reboot. I suggest checking logs.
@nickdb how do I check logs ?
Just changed from working local to via VRM but there I get also “Lost connection to server” what I supposse is also happening local but then giving the unreachable message.
