Thought I would post this script to help others.
This uses Digital Input 1 on a cerbo which is set to the generator.
You will need to open each node and select your multiplus device that your are using.
The flow also sets your Input Current for the VE.BUS.
Generator to shore changeover script.zip (2.1 KB)
Hope this helps!
