No Summed AC Load on Dashboard for MultiPlus-II and Multi RS
Hello Victron Community,
I’m seeking some guidance on how my GX device displays AC loads from two different inverters, powering 2 different (isolated) phases in my house . I’m hoping to see a combined total, but I’m currently only seeing the load from one of them (the multiplus).
My System Setup:
  • GX Device: Rpi Compute node 4 running Venus OS v3.64
  • Inverter 1: MultiPlus-II 10kVA (Single Phase) - Connected via MK3 to VE.Bus
  • Inverter 2: Multi RS 6000 (Single Phase) - Connected via VE.Can
  • System Type: Off-grid
The Issue: On both the local GX display and the VRM Portal, the main overview screen’s “AC Loads” tile only displays the power being drawn from the MultiPlus-II. The load from the Multi RS is not included in this figure.
I have confirmed that the Multi RS is online and powering its own loads, and I can see its individual performance data by navigating to it in the device list. However, the system is not aggregating these two load values on the main dashboard for a complete “Total AC Load” view.
My Question: Is it possible to configure the system to display the total summed AC load from both the VE.Bus MultiPlus-II and the VE.Can Multi RS on the main dashboard? If so, what settings do I need to change?
That’s not a supported standard system design.
→ it’s not possible to see the combined power on the dashboard
Thanks for the response. Is there a way to see the individual loads kinda like the way different solar output shows? There should be a workaround this? Is there?
You can see the output power of both phases in a custom widget of the Advanced tab.
But for easy summarisation I suggest to save the data in Influxdb and then summarise them in Grafan.
Thanks, this i can do as I have an alternative grafana dashboard. Just wanted to know if there was a way to have RS AC output load displayed on the VRM.
