Bart
(Bart van Middendorp)
27 September 2024 09:37
1
This is an installation with a Gerbo and a 3-phase MultiPlus. On the webpage and VictronConnect, the EV charger shows a fault, but on the Gerbo, you can see the EV charger without issues. Where am I making the mistake?
Ton_Gans
(Ton Gans)
27 September 2024 10:14
2
Did you enable Modbus TCP under Settings - Services
Lpopescu
(Lucian Popescu)
27 September 2024 10:27
3
are both devices in the same network?
Bart
27 September 2024 12:28
4
Yes, but in the VRM portal and on the Gerbo, it is visible and functional.
Bart
5
Yes, both are on the same home network.
Ton_Gans
(Ton Gans)
27 September 2024 12:51
6
Again, did you enable Modbus TCP under Settings - Services?
Because then you should see something like this:
Bart
27 September 2024 15:01
7
You are right, the problem is solved!
Thank you!
