New Victron 3 phase Multiplus-II 6k5 setup with 50.67 kWh storage (Gelderland, Netherlands)
Hy DYLAN,are the batteries DIY? 17s? wonderful setup,
Gefeliciteerd ,Frank
Thanks for your input. It is definitely much appreciated. I will monitor the system and the thermals for now but will take your suggestions into high consideration when I start making improvements.
Hi frank, dankjwel!
Het zijn in theorie DIY batterijen, maar ik heb ze afgemonteerd besteld. Het zijn batterijen met 16 cellen va 330Ah. Dit was goedkoper dan alle onderdelen los bestellen.
Heb je nog in de accu’s alle dc verbindingen gekontroleerd op een losse verbinding?
Een vrijwel losse verbinding veroorzaakt grote warmte ontwikkeling, wat maanden terug is hier over gepost, had brand kunnen veroorzaken.
How on earth did you manage to fit those five outputs onto the Lynx? Is there another Megafuse under the cover in front of the Cerbo?
Also, all the DC cables for the Multis have to be the same length… How did you manage that with those tiny cable ducts?
and then just have a look at the installation with an infrared camera at some point… :face_with_monocle:
I did indeed extend the busbar inside lynx to the 3D printed piece between the lynx and the screen to make the extra connection fit. It is indeed with another fuse, but it is a block fuse from blue sea systems.
The DC cables to each multiplus are exactly the same length. The DC cables run under the lynx busbar as I raised it with stand-offs to fit the cables behind it. This made the DC cable lengths significantly shorter and was able to fit them in the cable ducts easily.
I also indeed bought a IR camera today, which should arrive sometime next week. Curios to see what the temps do in high load.
Er zitten garantie stickers opgeplakt, dus als ik ze open maak zou ik die kwijt zijn. Ik heb wel de temperaturen gecheckt met de JK-BMS app en die zijn allemaal oké.
Ik zit zelf ook nog te twijfelen of het nu beter is om het te checken of niet.
@Dylanovich zeg heb je niet ergens ander een plek voor jouw installatie? Misschien kan de elektra onderverdeler daar wel blijven hangen, maar de rest zou beter verplaatst worden. Misschien niet iets waar je op zich te wachten, maar je moet hoe dan ook straks aan de PGS 37-1 voldoen.
Dan nog iets. Kabelgoot maakt het aangenamer voor het oog, maar de warmte zit daar dan wel in vast. Een mogelijk oplossing is bijvoorbeeld om de omvormers op een verhoging aan te brengen en de bekabeling daar onder aan te brengen. Een soort sandwich. Zelf heb ik twee platen waarvan ieder plaat een andere functie heeft. De bovenste voor montage van de omvormers, die daar iets voor (een strook onder de onderkant van de omvormers) voor de Lynx/DC kabels, en die daaronder (muur) de AC bekabeling.
Aan de voorkant zie je eigenlijk geen verschil. Alleen dat de kabels naar achteren verdwijnen. Vergt wat planning maar is prima te doen. Het is natuurlijk maar een idee, maar ik probeer liever iets constructiefs bij te dragen dan… iets anders :wink:
Je kan nog een stapje verdergaan door de mp inverters een aantal centimeters of nog meer naar voren te plaatsen zodat de ventilatie openingen niet langer achter de koker verschuilt gaat.
Dat is precies waarom ik een plaat gebruik voor de omvormers. In plaats van deze direct aan de muur te bevestigen. En ja die plaat zit inderdaad centimeters naar voren.
Onder de omvormers heb ik dan nog een strook met de lynx erop. Ook die zit weer een paar centimeter ervoor. De lucht kan er makkelijk achter/onderdoor naar de omvormers.
Attack ships on fire off the shoulder of Orion.
I watched C-beams glitter in the dark near the Tannhäuser Gate.
All those moments will be lost in time, like tears in rain.
Time to die.
Just kidding… Hope you oldies (but goodies) remember the monologue… :wink:
Blade Runner, one of best movie of the eighty’s.
Met dit formaat opslag (>20kw) wordt het zowiezo al geadviseerd je aan de pgs37-1 norm te houden, laat staan de nen1010
Kijk ook goed naar je verzekering, sommige hebben eisen aan de installatie/plaatsing sommige (nog) niet
Hoi Marc. Klopt. En terecht denk ik. Ook dat van de verzekering. Anders ben je enorm de pineut in geval van schade. Hier ook NEN 3140 in de lijst.
Fifty is a great balance between experience and being progressive, so it’s far too early to be classing people as old.
I’m not even against AI, as long as you know how to use it :joy:
P.S. As for “Blade Runner”, yes, it’s a classic, but I quite liked the remake “Blade Runner 2049” as well. :wink:
It’s not even off-topic… and it clearly falls under the Victron topic…
something about the “chips on Fire in the Orion”…
orion
… by the way … one of the few successful sequels :slightly_smiling_face:
Bedankt voor deze constructieve suggestie :smiley: . Dit klinkt voor nu wel een van de meest haalbare korte termijn verbeteringen.
Je zou ook ventilators (fans) kunnen plaatsen. RobertDIY op YT heeft daar een filmpje over. Kost niet gek veel geld. En vergeet niet te zorgen voor voldoende geforceerde ventilatie. Onder aanvoer. Boven afvoer. Gratis warmte voor als het kouder is :grinning_face:
I got 3x jk bms too, but they are almost aleays a couple of percentage off (lower) compared to the smartshunt 500 i have, using that one too for metering. But still little hesitant if this ok or not.
Read jk isn’t the best in soc measures…
I am using both parallel, the SmartShunt as the battery monitor and the JK BMS for controlling the MP2. Here you can see how much the current measurment can differ between both:
And this results in really bad SOC measurement. Even when discharging a freshly balanced battery from 100% to 30% within just a few hours the SOC can differ as much as 16 percent points. And when the battery can’t balance every day the SOC difference cumulates quickly. This is after 2 days:
