MultiPlus SOC dropping when charger in Storage mode (UPS application) - Chute de SOC en Storage Mode
I am using Multiplus with AGM battery for backup (UPS) function.
The SOC of the battery is decreasing when Storgae Mode is activated.
I found a similar discussion on the archives, which has not been completely solved :
https://communityarchive.victronenergy.com/questions/1273/multiplus-soc-dropping-no-load-storage.html
As anyone experienced a similar issue ?
I had this same issue with a multiplus 12/1200. Rather than RMAing and waiting on replacement or voiding the warranty and doing the hotwire trick that’s at the bottom of the archive post. I simply added a smartshunt to the system. Sure the ACIN and ACOUT are still slightly different at times but the SOC never moves unless current is drawn from the battery.
Problem solved by replacing the Multiplus !
