I recently stepped into the realm of Victron and are building an RV setup for my trip.
However, I’m experiencing some issues with my build;
After turning on the Multiplus in the “ON” possition, the Cerbo starts beeping and the error presented is: “Voltage sense error”.
The “bulk” and “absorption” buttons are blinking simultanously.
The Multiplus does not invert!
I have the following devices list in place:
- Multiplus (1) 12/3000/120A (230V) - purchased second hand (connected through VE.Bus to Cerbo)
- Cerbo-GX S
- SmartShunt 500A (connected through VE.Direct to Cerbo)
- Orion XS 50A 12V DC-DC (connected through VE.Direct to Cerbo)
- WattCycle LifePo4 280Ah
My Multiplus is connected and has 13V supplied to its battery terminals.
I have no wires connected to the battery sense connections (and if possible I don’t intent to, if it is not required).
When enabling DVCC (and configuring to use the SmartShunt), and connecting to Shorepower (AC-IN) - the multiplus is charging and does 230V passthrough.
However, when the shorepower is revoked, the Multiplus doesn’t invert anymore.
I did use VE.Configure to setup the Multiplus for the Lithium battery profile.
Can someone assist me in what I need to look at?
Kind regards,
Mike
