Hi all
I picked up this 7 year old Multiplus 12/1200/50 and I have been testing it out and it seems to charge my lithium 200ah at 40amp until it was fully charged without any issue (battery is brand new)
But when I tried to invert from the battery it worked fine for the first hour (13.4v) but then i started to low voltage alarms and overload alarms I was only drawing 100w AC at the time
I’ve checked the cabling and connections and all are clean and firm I did notice when it overloaded the dc it blow the 100 amp mega fuse I had in-line
Could my Multiplus have an internal short or conversion issue causing it to act this way
Did you buy it from @DuivertNL otherwise how would he know what cable that is? Please add a clear description or better. Add a picture of what you see on that battery wire. TIA.
Also. Blowing a 100A fuse is really bad. Something is obviously wrong. Have a multimeter handy? Please check all wires. Must be something wrong. Hopefully not the Multiplus
