Hello everyone,
I have a grid-tied system configured as follows:
The solar energy is converted directly to AC.
The MultiPlus-II will use the excess solar energy to charge the batteries or feed power into the grid.
It will also discharge the battery or use grid power to compensate for any shortfall in solar production.
In case of a power outage, the MultiPlus-II will disconnect from the grid and continue supplying the loads.
I wanted to know if it is possible to prevent excess solar energy (once the batteries are fully charged) from being fed into the grid. I plan to use a non-Victron solar inverter for the photovoltaic system.
Thanks in advance for your help!
