I am running a mobile ESS system based on multiple Victron MultiPlus-II inverters with battery storage. The whole system is controlled by an external software (LabVIEW).
Through a communication table (register IDs), I send the following parameters to each inverter:
Active power setpoint per unit (e.g. -5000 W per inverter for discharge)
Permission to charge / discharge
The system is used for different testing and validation purposes.
System setup:
3-phase connection to building grid via CEE 32 A supply
External switch logic with contactors
All inverters switch on after ~60 seconds in a coordinated sequence
Initial state is pass-through mode (grid is directly passed through)
Control sequence:
System starts in pass-through mode
Power setpoints are written (e.g. -5000 W per inverter)
A signal enables “discharge allowed”
Expected behaviour: all inverters ramp up to the requested power within seconds
Observed behaviour:
First start (after grid connection):
System works as expected
Power setpoints are reached within a few seconds
Fast and stable response
After grid disconnection and restart:
Power setpoints are only reached very slowly
Ramp rate is very low (around ~3 A per minute equivalent)
In some cases, target power is barely reached or takes a very long time
When this slow ramping happens, the increase is completely constant over time.
It is not stepping or oscillating, but a steady linear ramp until the target value is reached.
It then takes several minutes to reach the requested power setpoint: e.g. 7 minutes for reching 5 kW
Question:
What could cause this very different behaviour between first start and restart after grid loss?
Specifically I would like to understand:
Does the MultiPlus/ESS system have an internal state after grid loss that limits ramp speed?
Are there protection or synchronization mechanisms (grid reconnect, DC bus stability, etc.) that reduce power ramp rate?
Are there known conditions where power ramping is strongly limited (SOC, grid code, frequency/voltage stability, ESS state)?
Could this also be related to how external control via registers is applied (timing or state transitions)?
Can anyone explain this behaviour and suggest how to fix it?
