Multiplus II "Continue with missing phase"
Last night, there was missing a phase - in the grid, around me.
Due to the low daly solar, it was in cheap reate - where i chargeed my battery.
I got ‘Grid lost’ warning - and runned on the battery, until the phase returned.
I didt not charge my battery, while i was missing 1 phase.
Is there a setting “Continue with missing phase” ???
My setup
3 × MultiPlus II 48/8000 (FW 552)
48 kWh battery
  • solar
    RPI with Venus software
Some place they write you can set it in VE.Bus System Configurator - i cant find it - I am running 90.09.158
When you initially configure the 3phase setup there is a tickbox - switch as a group.
You can disable this but it does not work with ESS.
If it does not work with ESS - Then there i no need to run the “initially configure” again. - Then i have to hope for no grid failure - in the dark session.
The area with 23 houses - has gone form
Gas heating > Heat pumps
Regular cars > EV cars
  • Hope they can change to greater fuses, for this road.
    it was 1½ hour after the cheap traiff started - so every one is charging there EV !
    1½ hour - can fit medium overload on the fuses ( i was drawing 3X25A - that is my official limmit )
