MultiPlus-II 30kVA + Fronius (45kW) + Generator ATS: 30kW Grid Export & Protection Logic
​Hi everyone,
​I am configuring a system with a Cerbo GX, Pylontech battery bank, and dual Fronius grid-tied inverters, operating under a 30 kW grid export limit.
​The system is connected to the grid, but also includes an ATS (Automatic Transfer Switch) to fail over to a backup generator during grid outages.
​Here is what I need to achieve:
​Grid-connected mode: Cerbo GX controls the Fronius inverters via Modbus TCP to dynamic throttling/limit total feed-in power to 30 kW, while allowing excess PV production to charge the battery bank and supply home loads.
​Off-grid / Generator mode: During a grid outage, the ATS switches the system to generator power. Cerbo GX handles generator start/stop relay logic. In this mode, PV output must be strictly controlled (or throttled/disconnected) to prevent feed-in/backfeeding into the generator.
​Safety / Isolation: In case of communication loss or emergency backup scenarios, what is the best practice for isolating or throttling the Fronius inverters (e.g., via Cerbo GX relay-driven contactors or Modbus control) to prevent exceeding grid export rules or damaging the generator?
​Could anyone share recommendations, Modbus TCP setup tips, or Cerbo GX relay configuration examples for this exact setup?
​Thanks in advance for your support!
