The AC2-out on my Multiplus-II does not have any power when MP-II is turned OFF.
The system is in a boat connected to the grid, and I’m preparing for winter. I need power from the grid to be able to have some heat and a dehumidifier inside the boat.
I don’t want to have the lithium batteries on charge all the time, and plan to control the charging by MP-II ON/OFF remotely via VRM.
When installing the system I was told that the AC-2 OUT would give power even if the MP-II is turned OFF. That’s not the case on my MP-II, no power from AC-2 OUT when MP-II is turned OFF…?
If MP-II is ON, the AC-2 has power, but then also the charger is ON, and that I don’t want.
Any respond will be much appreciated.
